DIALux DIALux 4.3.0.0
Discusión en 'Diseño de iluminación' iniciada por agonz46, 22/12/2006.
  1. agonz46
    agonz46 Maestro
    Ya se puede descargar la nueva versión de Dialux 4.3.0.0.
    Estas son las novedades que presenta el software:
    DIALux 4.3
    • Calculating the light distribution, taking into account the spectral radiation of the light
    • The selection of lamps from a lamp PlugIn for a desired luminaire. The selected lamp from a lamp PlugIn can contain the following information:
      • Technical information like luminous flux, power consumption, voltage, etc.
      • A new light distribution curve (LDC) for example with reflector lamps
      • Maintenance factors for the lamp
      • Spectral light distribution
      • Pictures, text, article names and numbers
      • Further marketing relevant information
    • For those luminaires which have no spectral light distribution given in the database and / or if there is still no lamp PlugIn installed, DIALux offers a number of standard lamp spectra
    • Colour filters for luminaires. DIALux includes a large quantity of available and measured colour filters which influence in addition to the used lamp the spectral light distribution of the luminaire
    • Improved diagrams for the luminaire technique. Better resolution and better design for the monitor and for the printouts
    • A large quantity of new furniture and textures
    • Now it is possible to copy, move and delete furniture and textures within the furniture and colour tree of DIALux
    • If a luminaire has more than one light emitting element, up to four diagrams are now shown in the luminaire lists
    • Cone diagrams now show the half peak angle also for not rotational symmetric luminaires and also for uplighters
    • Luminaires can be aimed towards C90 Gamma 0 angle in addition to C0 and Gamma 0 and maximum light intensity
    • Camera paths for animations can now easily be handed over to the PovRay Raytracer
  2. agonz46
    agonz46 Maestro
    Buenooo ya empezamos, lo he instalado en el portátil con XP 32bits y funciona bien, lo instalo en el sobremesa con XP x64 y falla la instalación en el último momento (fallo del Windows Installer me dice).
    Para mi que tiene algo que ver con el Framework 2.0:mad:
  3. Shaka
    Shaka Novel
    No tuve problemas con la instalacion del dialux, esta interesante la nueva base de datos agregada con la cual tenemos los flujos y datos de las lamparas.
    al instlaar tambien te instala un framework, tal vez ese sea el problem.
  4. Mierda cochina, no se ni cargarle las bases de datos de lamparas :eek: :eek: :eek:
    ¿Alguno puede explicar de modo simple como se hace?
    Estamos intentando empezar a manejar este programita, por necesidades como es logico del CTE.
  5. Mies
    Mies Gran experto
    Joer estoy igual que tú, acabo de instalar el programa porque necesito calcular la iluminación de un local....cagontó...el manual del programa solo tiene 250 páginas!!!
    ya no damos abasto...
    ...ve proponiendo un cursillo del dialux este....
  6. JLMolina
    JLMolina Experto
    @EL_INUTIL_© ya sabes a quién has de pasarle el manual para que lo digiera un poco. Seguro que se le da también bien. :D
    Alguien me dijo una vez que no tenía tiempo de aprender todo lo que necesitaba por el CTE, que se jubilaba antes (ya era talludito) :eek:
  7. agonz46
    agonz46 Maestro
    A ver Inu, no te sulfures:p.
    Para poder utilizar las luminarias primero te has de descargar el plug-in de algun fabricante colaborador de Dial. Tienes, por ejemplo, OSRAM, PHILLIPS, ARTEMIDE, ERCO, ORNALUX, SIMES, INDALUX, etc. Para descargarte los plug-in's tienes que ir a la web del fabricante.
    Una vez descargado el plug-in e instalado, abres Dialux, en las pestañas de abajo seleccionas el foco (selección de luminarias) y donde pone "catálogos Dialux" aparecerá el plug-in que has instalado. Doble click en el catálogo y se te abrirá la pantalla para poder insertar luminarias.
    A ver si tengo tiempo y empiezo un tutorial, de momento ya está la parte de descarga de plug-in's;)
    Saludos:cool:
  8. agonz46
    agonz46 Maestro
    Ya está disponible para descarga el manual en castellano de la versión 4.3. y la nueva versión 4.3.0.3
  9. Mies
    Mies Gran experto
    El manual no es muy aclaratorio...... menos da una piedra.
  10. agonz46
    agonz46 Maestro
    Pensaba que iba a ser la ayuda del programa y es el manual en pdf.:mad:
  11. LYKKE
    LYKKE Veterano
    instalar el programa Dialux
    ustedes pueden??
    ami me da error y aun no se porque podra ser,..
    que experiencia tuvieron ustedes?
  12. Ersherdon
    Ersherdon Promesa
    @agonz46
    Hola.
    Yo tengo el mismo problema ese del windows installer 3.1 y parace que tu lo has solucionado. Me podrias ndicar como lo has hecho?.
    Un saludo, Ersherdon.
  13. agonz46
    agonz46 Maestro
    Pues la verdad es que no me acuerdo :eek:.
    Me parece que había un problema con esa versión de Dialux:confused: El caso es que hace poco lo instalé en otro equipo y no tuve problema alguno.
  14. gap
    gap Júnior
    alguien q lo haya usado puede decir si da las justificaciones necesarias q pide el cte?
    alguna otra opción mejor?
    gracias
  15. Sucio
    Sucio Veterano
    Si, te permite sacar ciertos datos necesarios a cambio de meter otros datos.
    No te podría decir, pero lo que si te diría que empezaras con el light, que es mucho más fácil (aunque + rígido) y te va al meollo de la cuestión. El paso del light al de los listillos( el gordo) es menos traumático.
    Para resumír diría que el programa dialux es intuitivo. (con un mínimo de conocimiento(como por ejemplo el mio) y algo de ayuda...)
  16. gap
    gap Júnior
    gracias sucio.
    llevo dos dias peleándome con él, y creo q voy sacando cosas....
    he visto el ligth y me parece muy sencillo. gracias!
    alguien sabe lo q es una:
    "iluminación con reactancia y sensor luminoso"?
Compartir esta página
